CGM says its not a picture
bryonfriesen
Post by bryonfriesen »
Trying to convert a cgm to a jpg. When I try converting it, it states that it is not a picture. The image does display in my Arbortext program. Is there something different about my cgm. I have attached a sample.
Thanks
Bryon
bryonfriesen
Re: CGM says its not a picture
This was exported as a CGM version 4.
Bryon
cgm format is not supported
ChuanChe
Post by ChuanChe »
I've posted a topic about this. It's the same problem i have with *.MIX files created with Microsoft Photodraw and Picture It!
I believe that XnConvert could read them, but i've got the same message. Maybe there's a pluggin to download anywhere?
Thanks a lot
bryonfriesen
Hi Pierre, under compatibility it says cgm is supported. Do you mean version 4 of cgm is not supported, or cgm to jpg is not supported.
Thanks
Bryon
where do you see cgm?? cgm is not supported at all
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=18715#p18715]Does XnView support CGM (Computer Graphics Matafile)?[/url]) wrote:
multiedit wrote:... and, if it doesn't (it seems like that, anyway), does the Author have plans on including CGM format support in future releases?
You have CGM support by thid party plugin CADIMAGE
In order to enable support for these vector formats, you have to download…
… from the CadSoftTools site (Plugins for third-party programs) and extract the contents of the archive into the Plugins subdirectory of your XnView installation.
Installation of the CS Plugins Manager (CS_Manager.exe) is optional.
