Mac hangs up on XnViewMP launch
pgarr
Post by pgarr »
Until recently I got XnViewMP running normally.
Recently, whwneve I launch XnViewMP, my mac hangs up because the programme is not responding.
If I change use, XnViewMP runs normal?!
the error message:
Date/Time: 2015-03-23 17:42:48 +0000
OS Version: 10.10.2 (Build 14C1514)
Architecture: x86_64
Report Version: 21
Command: XnView
Path: /Applications/XnViewMP.app/Contents/MacOS/XnViewMP
Version: 0.72 (0.72)
Parent: launchd [1]
PID: 2799
Event: hang
Duration: 1.80s (process was unresponsive for 18 seconds before sampling)
Steps: 19 (100ms sampling interval)
Hardware model: MacBookPro8,2
Active cpus: 8
Fan speed: 2005 rpm
Any sugestion?
Pedro Garrido
Re: Mac hangs up on XnViewMP launch
please try to rename ~/xnviewmp/xnview.ini?
pgarr
Post by pgarr »
Hi Pierre,
It did not solve the issue. After openning, it still hangs up.
Date/Time: 2015-03-23 23:42:58 +0000
Report Version: 21
Command: XnView
Path: /Applications/xnview.ini?.app/Contents/MacOS/XnViewMP
Parent: launchd [1]
PID: 1833
Event: hang
Active cpus: 8
Fan speed: 2291 rpm (+149)
pgarr
Post by pgarr »
Hi Pierre,
I supose I have not understood your sugestion.
"please try to rename ~/xnviewmp/xnview.ini?"
I do not have a directory named "/xnviewmp/". The file xnviewmp.app is located at the Applications directory.
Regras,
Pedro
You have not a folder .xnview or .xnviewmp in your home folder?
pgarr
Post by pgarr »
No, I have not.
I just download file from your site and after unziping XnViewMP-mac 23.25.47.tgz, I moved the file XnViewMP.app to my Mac Applications.
I did not create any directory at all.
try to drag&drop a picture file on XnViewMP's icon?
pgarr
Post by pgarr »
After using your sugestão, XnView does not open, it opens the image with the following info at the upper left corner:
399/769 - IMG 3818
JPEG TrueColor (v1.1) - 87KB - 480X640
({Date Taken}) ({Mark}) ({Model}) (100%)
and the mac freezes again...
I must say that after removing XnViewMP and reisntall it again, instead of a new installation I got again the old configuration!?
Is there a place/file where I can clean up the old installation?
Once again thanks a lot for you kind cooperation,
Pedro
pgarr
Post by pgarr »
Hi Pierre,
Although my last post, after reboot, XnVieMP began to work!
Thanks,
Pedro
