ShellEx: Option for EXIF rotated JPEGs
Lesmo16
Post by Lesmo16 »
I like (and use) the fine xnView Shell Extension very much. :)
It would be perfect for me, if it would show JPEGs rotated according their EXIF orientation flag.
Perhaps it's possible to implement this great new feature of xnView 1.80 as option to the ShellEx.
Everyone who believes in telekinesis, raise my hand!
Re: ShellEx: Option for EXIF rotated JPEGs
Lesmo16 wrote:I like (and use) the fine xnView Shell Extension very much. :)
Ok, i'll add it. An option for ShellEx or i use the same option as XnView?
Lesmo16
Post by Lesmo16 »
If the ShellEx depends on an installed xnView, then it may take that information from xnView.
BTW: The language option is redundant.
ShellEx should also take it from xnView's INI. If the xnView language isn't available for ShellEx, then it remains english.
Not sure, if user use ShellEx without XnView
Lesmo16
Post by Lesmo16 »
xnview wrote:
Lesmo16 wrote:
xnview wrote: Ok, i'll add it. An option for ShellEx or i use the same option as XnView?
xnView Shell Extension View doesn't make sense without xnView - for sure!
What about the language suggestion?
Lesmo16 wrote:What about the language suggestion?
I prefer to keep it, currently ShellEx check language (first startup) used by XnView
Dreamer
Post by Dreamer »
Added.
Closed.
