.jpg to multipage .pdf
Pavel K
Post by Pavel K »
I have 2 files in .jpg format. I want to make a single .pdf file. Is it possible to do with XnConvert or XnView?
I tried it, but it made me 2 .pdf instead of 1. (I choose 2 .jpg files in input tab, go to Output tab, choose pdf with "Convert multipage file to multipage file (When possible)" and "Convert all pages from multipage file". Tried to find "Convert all pages to multipage file, but failed :) )
Re: .jpg to multipage .pdf
Pavel K wrote:I have 2 files in .jpg format. I want to make a single .pdf file. Is it possible to do with XnConvert or XnView?
You can use XnView:
In the viewer: Tools > Multipage file > Create
In the browser: Create > Multi-page file...
Or in XnViewMP (in the browser only) Create > Multi-page file...
Note that in XnViewMP compression settings are set in the viewer: File > Format settings...
But not using XnConvert, as an option to output to a multi-page file hasn't been added yet... :(
Pavel K
Post by Pavel K »
Not using XnConvert, as an option to output to a multi-page file hasn't been added yet... :(
You can use XnView:
Or the equivalent in XnViewMP (in the browser only) Create > Multi-page file...
It's solved. Work well at XnView 2.32.
Thanks cday 8) Topic can be closed.
