wmark is not positioned bottom-right -breaking change 6.70?
hmayer1980
Post by hmayer1980 »
recently I setup a new laptop and had to install nconvert again. This is a newer version as the one I have created my batch file with.
In the new Version the watermark is located at the top left even though if use the bottom-right wmflag.
Also the quiet option is not so quiet anymore...
The Command at the moment is like
echo on
cls
setlocal
set workdir=%1
set batchdir=%~dp0
set nconvert="C:\Program Files\XnConvert\nconvert.exe"
rem "Generate L Thumbnails"
%nconvert% -quiet -overwrite -o $thumbs\phoca_thumb_l_%% -opthuff -dct 2 -subsampling 2 -keepfiledate -rexifthumb -ratio -rtype lanczos -rflag decr -resize longest 800 -wmfile %batchdir%watermark-large.png -wmflag bottom-right -wmopacity 100 %workdir%\*.JPG
Have there been breaking changes from Version 6.56 (the exported help notes this old version number) to Version 6.70 (the current version)?
How do I fix the wrong position of the watermark?
Even with quiet the batch outputs something like
Marker : e1  13820
Marker : e1  2556
If I remove the quiet it shows the same output so it might not be an error??
I wonder if I could access the old versions executable somewhere to download the old version instead of the current one? On the other hand its a good thing to improve the software.
Any help is appreciated.
Re: wmark is not positioned bottom-right -breaking change 6.
you need to put params for watermark before -wmfile
hmayer1980
Thank you, that does the trick!
also just for future references - it worked in the old Version with any orther. See also this Post http://newsgroup.xnview.com/viewtopic.php?f=57&t=30294 - I have used the order before and it worked...
Also in the helpfile - and I tried to keep the order as it is in the hlep - ist the other way arround...
-wmfile file : Watermark file
-wmpos x y : Watermark position
-wmflag flag : Watermark Position
Again, this comments are just to improve the Software, and many thanks for the workaround!
DilSpi
Post by DilSpi »
would love to see the help-files order also as hmayer1980 suggested.
text seem to need a special sort-order too.
maybe it would help to better understand to give a general advice how the order should be used.
Dil :)
lian
Post by lian »
+1
I lost too much time how to make this wmflag worked.
SF, illustrations et mes BD sur mon blog: https://www.li-an.fr/
Windows 10 Home 64 bits
