I would like to see my pictures in Fullscreen mode - all of them. For this I would like to use this "Fit image to window" as default fo all images.
But it seems XnViewMP does not have such setting - or - it screws it / forgets it, e.g. when opening a new image from Windows Explorer, where XnViewMP switches back to Viewer mode.
Yes, I can press '/' but having the images fitting to window per default would be great.
Is there any setting I can use for that ?
Thanks and best wishes,
Jo.
P.S. I am using Windows 8.1 ...
Fit image to window - as default ? And permanent ?
jo2h2
Re: Fit image to window - as default ? And permanent ?
if you change to 'fit image to window' the setting is used when you open a new picture, i have this behaviour
