Iam using xnview for long and really like it. I have urgent request for a function and have registered only for this. I would like that when I have xnview opened with many files (16 like files) and I close it, then when I open xnview again, after a while, it should open the last opened files by default. and not just a window with no files (last opened).
Iam using latest version of xnview, and have these options checked - GENERAL -> Only one Instance, view -> No multiple view for same file.
Images open in the xnview same window in tabs onthis system.
I have tried all options but cant get this thing done to open last files when I open xnview again. and I dont want to open all files by recent files, as I have 16 files opened at a time.
If this feature is in xnview currently, please tell me to find the setting option, and If this feature is not there in xnview current version, please add it soon, I need it desperately, in the to release, portable and setup xnview. I would seriously donate for this very feature only. Thanks.
XNVIEW TO OPEN LAST SESSION
- Forum Librarian
Re: XNVIEW TO OPEN LAST SESSION
XnView Classic is not capable of restoring open tabs, …
… but MP can: When the program is closed, you will be asked if “you want to save this session”.XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?t=22923&p=107307#p107307]Remember Open Tabs on Closing XnView[/url]) wrote:
A workaround would be to create a special shortcut:
[color=green]XnView_Session.lnk[/color] wrote:"C:\Program Files\XnView\xnview.exe" -filelist session.txt[color=green]session.txt[/color] wrote:X:\Test\photo_01.jpg
- Related topic: Restore last opened files...
