Zoom in/out to a specific percentage
pintree3
Post by pintree3 »
It seems that it is only possible to zoom in and out to a specific percentage, is there a way, via plugin or something to zoom to something you want 93%, 67%......? I find this to be the only thing I dislike about xnview--especially since there is nothing between 100-150.
Thanks
pintree3
Re: Zoom in/out to a specific percentage
Post by pintree3 »
About a year has passed by and I am still wondering if this is possible. I now have the new 'XnViewMP. Any help, anyone? :-)
pintree3 wrote:About a year has passed by and I am still wondering if this is possible. I now have the new 'XnViewMP. Any help, anyone? :-)
in XnView MP, you can edit zoom value
pintree3
Post by pintree3 »
Edit how? What do you mean/ DO you mean in the Settings menu where it says, "Zoom step" with choices relative and fixed/ I had sent hat but am not sure what it means. But what I meant (and maybe this is what it means) is that I would like to be able to quickly (as in Adobe Reader or Acrobat as an example. place in a box the percentage I want. If the settings do this then how do I get my new results once I'm away from setting?
you have the percentage in the status bar
xnview wrote:you have the percentage in the status bar
Ah...
In XnView Classic the percentage zoom is displayed in the status bar but there is no way of entering a percentage directly... :|
In XnView MP the percentage zoom is displayed in the status bar and values can be entered directly... :D
pintree3
Post by pintree3 »
Oh my. What's it doing down there? :-) I hadn't noticed it.
Thank you
How do we mark this topic as solved?
pintree3 wrote:Oh my. What's it doing down there? :-) I hadn't noticed it.
I hadn't noticed it there either, so possibly one day an option to display zoom on the toolbar, and as the default location??
But I guess not many people really need the facility, or there would have been more past requests?
