Hi to all, i've got 2 problem with last conversion, i don't know if they are bugs:
1) I select a folder, after loading all files i write a name filter ".jpg" and software select all files that end with ".jpg" but also all files that contains simple jpeg string (ex. imajpg.gif) that i think is wrong (why "." char is not searched in string?)
2) After this wrong conversion i notice that an mp3 file (ex. musijpg.mp3) also is converted to image file, but original extension and file contents is not checked during conversion ?
Thanks for help!
Name filter and file type
Re: Name filter and file type
RegExp is used here, so try something likealbesp77 wrote: 1) I select a folder, after loading all files i write a name filter ".jpg" and software select all files that end with ".jpg" but also all files that contains simple jpeg string (ex. imajpg.gif) that i think is wrong (why "." char is not searched in string?)
[.]pngthe embedded jpeg thumbnail can be readed2) After this wrong conversion i notice that an mp3 file (ex. musijpg.mp3) also is converted to image file, but original extension and file contents is not checked during conversion ?
