Install XnView incl. "the most used associations"
Peter2
Post by Peter2 »
There is the command "Options - Associations - The most used". I would that this command is executed at the end of the setup-process.
How to make? Is it possible to modify the setup process? Or can it be done via command-line?
Peter
Re: Install XnView incl. "the most used associations"
currently no way
