deleting programs from the contextmenu
heiron
Post by heiron »
I'm working with XnView 2.32 for Windows 8.1 64bit.
I have several programs in the contextmenu ie Photoshop, Lightroom and DXO for external use.
Now I've changed from an older program version to a newer one which means the old link doesn't work any longer.
How can I delete this old version from my XnView 2.32?
Thanks for helping
Ron
Re: deleting programs from the contextmenu
which link do you want to remove?
heiron
Post by heiron »
When I rightclick an open picture in XnView I get the contextmenu where I find different programs
("Open with...") to continue the working process.
I can also use a shortcut like CTRL+1 or CTRL+2...
One of this shortcuts is blocked by a program which is not used any longer.
Now I want to delete this program/shortcut
Ron
'open with' in XnView, right?
you need to edit the xnview.ini
heiron
Post by heiron »
:D
Yes, thanks, that's it
