0.75 beta Does not work on closing the tab Ctrl + W
Koyotero
Does not work on closing the tab Ctrl + W when the Russian keyboard layout. When the English keyboard layout this hotkey starts. OS Win7x86.
Re: 0.75 beta Does not work on closing the tab Ctrl + W
and no problem with other hotkeys?Koyotero wrote:Does not work on closing the tab Ctrl + W when the Russian keyboard layout. When the English keyboard layout this hotkey starts. OS Win7x86.
Koyotero
Still not working in the Russian keyboard layout Ctrl +/. This problem is likely due to the use of in 0.75 QT5.
no problem with 0.72?Koyotero wrote:Still not working in the Russian keyboard layout Ctrl +/. This problem is likely due to the use of in 0.75 QT5.
Koyotero
Looked more. At 0.72 does not work cmd_fitAll and cmd_realSize When the Russian keyboard layout. In the working 0.72 Ctrl + W. At 0.75 do not work all three teams: cmd_fitAll, cmd_realSize and Ctrl + W.xnview wrote:no problem with 0.72?Koyotero wrote:Still not working in the Russian keyboard layout Ctrl +/. This problem is likely due to the use of in 0.75 QT5.
I've tried with russian language, and no problem with Ctrl+WLooked more. At 0.72 does not work cmd_fitAll and cmd_realSize When the Russian keyboard layout. In the working 0.72 Ctrl + W. At 0.75 do not work all three teams: cmd_fitAll, cmd_realSize and Ctrl + W.
What do you means by cmd_fitAll & cmd_realSize doesn't work?
Koyotero
CTRL + W is not working it is in Russian layout. When switching to the English hotkey starts working. In my opinion the key concept in explaining the causes of this phenomenon - the keyboard driver when switching layouts passes into the application code represents the key pressed, and she of course ignored. Indeed, in the application instead of CtrlW comes CtrlЦs and this is a different team.xnview wrote:I've tried with russian language, and no problem with Ctrl+W
Sorry, made a mistake. Didn't take into account that there are on / Numpad.xnview wrote:What do you means by cmd_fitAll & cmd_realSize doesn't work?
but it's strange that in 0.72 it's worksKoyotero wrote:CTRL + W is not working it is in Russian layout. When switching to the English hotkey starts working. In my opinion the key concept in explaining the causes of this phenomenon - the keyboard driver when switching layouts passes into the application code represents the key pressed, and she of course ignored. Indeed, in the application instead of CtrlW comes CtrlЦs and this is a different team.
Koyotero
Heard that such problems may be associated with the use of QT 5. A version 0.72 uses an older version of QT. After all, this is a major change in the 0.75. Unfortunately I'm not a programmer, so I can not say for sure what could be the problem.xnview wrote:but it's strange that in 0.72 it's works
