Strip all metadata without altering original image.
Katamara
Post by Katamara »
Hello.
I am not sure about the options for nconvert (linux) to remove all metadata from jpeg/tif images
and 'not' alter the original image content.
I tried:
Questions;
1. Will the above remove all metadata, including EXIF, XMP, COMMENT, ICC PROFILE, MAKER NOTES ?
2. Will the above remove metadata and 'not' alter the image contents ?
3. How can I preserver the original 'Creation date/time' or 'DateTimeOriginal' ?
4. Is nconvert the 'only' available method to use commands on the command line ? i.e. XnviewMP
Thank you.
Re: Strip all metadata without altering original image.
Katamara wrote: 1. Will the above remove all metadata, including EXIF, XMP, COMMENT, ICC PROFILE, MAKER NOTES ?
yes
Yes
-keepfiledate doesn't work??
yes
Katamara
Post by Katamara »
Thank you Pierre.
Regarding: -keepfiledate
I can't be sure. I was watching the 3 dates shown in XnViewMP when I did the command,
and they all changed. I didn't investigate this further.
If I understand you correctly, I will be able to preserve the Creation Date exif with -keepfiledate.
If I check the image 'before' with for example, exiftool...
$ exiftool -s -DateTimeCreated DSCF8557.tif
then I do: $ nconvert -rmeta -overwrite -keepfiledate DSCF8557.tif
it 'should' preserve the exif DateTimeCreated ?
Thank you.
sorry but -keepfiledate works only on windows
And on linux it's not possible to change created_date_time's file
Katamara
Post by Katamara »
Thank you Pierre, ambitious thinking on my part.
Best regards,
[Solved]
