No new bugs between 0.72 & 0.75??
m.Th.
Re: No new bugs between 0.72 & 0.75??
Ok, ok...
For me, a showstopper is that the Full-Screen subsystem (F11) cannot be put on the 2nd screen anymore, even if ”Dual Monitor” is checked in Options.
m. Th.
m.Th.
Also, it seems that the Sort Header above of thumbs doesn't work anymore (even if this is a bug which it seems that it is present also in 0.71)
m. Th.
with 0.72 no problem?m.Th. wrote: For me, a showstopper is that the Full-Screen subsystem (F11) cannot be put on the 2nd screen anymore, even if ”Dual Monitor” is checked in Options.
i think that this problem is in previous version toom.Th. wrote:Also, it seems that the Sort Header above of thumbs doesn't work anymore (even if this is a bug which it seems that it is present also in 0.71)
m.Th.
Dunno. I skipped it. In 0.71 works ok.xnview wrote:with 0.72 no problem?m.Th. wrote: For me, a showstopper is that the Full-Screen subsystem (F11) cannot be put on the 2nd screen anymore, even if ”Dual Monitor” is checked in Options.
m. Th.
could you contact me about this problem?m.Th. wrote: Dunno. I skipped it. In 0.71 works ok.
HanVroon
Just did a short test at work for some "confirmation help". At work I have 2 monitors.
In version 0.71 and 0.72 the full screen image appears on the other screen (no matter if XnViewMP is left or right, full screen appears nicely on the other screen.
With version 0.75 full screen appears on the same screen, not the other screen.
Regards,
Han
Regards,
Han
Newtomic
Hi, i'm new to this forum and before anything else I just wanna say Thanks for the great programs (XnView, XnViewMP, XnShell, etc.) I use them for many years by now and still think it is the best img viewer for Windows.
Now about the 'file associations' more precisely "Associate files with XnViewMP.exe" program it works in Win7 if we put back the files "QtCore4.dll", "QtGui4.dll" and "QtNetwork4.dll" from v0.72 in the root of XnView folder, and then rename the new "xnviewmp.exe" to "xnview.exe", and after that even the button <Run the File association(s) tool...> inside the app works fine.
Other than that until now the 0.75 beta is working fine for me.
could you download the last beta version?HanVroon wrote: With version 0.75 full screen appears on the same screen, not the other screen.
HanVroon
Hi Pierre,
Sorry for the late reply... i was on holiday.
With beta 0.75 from 11-06-15 fullscreen works fine here on 2 screens.
- XnViewMP opened on the second screen.
- Fullscreen opens on the first screen.
- When "Dual monitor: Use second monitor" is checked, fullscreen opens on the second monitor also.
Kind regards,
Han
Kind regards,
Han
HanVroon
Correction,
The behaviour is a bit strange, I thought it was OK, but not jet:
When XnViewMP is on the first screen, fullscreen always opens on the first screen, no matter if "Dual monitor: Use second monitor" is checked or not.
When XnViewMP is on the second screen, fullscreen will open the first image on the first screen, after pressing Esc, the next image is opened on the second screen, no matter if "Dual monitor: Use second monitor" is checked or not.
So, the checkbox has no function now.
Regards,
Han
Regards,
Han
i can't reproduce.HanVroon wrote: When XnViewMP is on the first screen, fullscreen always opens on the first screen, no matter if "Dual monitor: Use second monitor" is checked or not.
UrbanCoyote
It crashes too much under W10.
The easiest reproduce is leave xnview open, then open up a new desktop. Most of the time it will crash.
Rarer, but still present is leaving xnview open then goto another program on the same desktop
