Screen Saver & Monitor Power Saving During Slideshow
rtbcomp
Post by rtbcomp »
The screen saver and monitor power saving need to be disabled during a slideshow.
rtbcomp
Re: Screen Saver & Monitor Power Saving During Slideshow
Post by rtbcomp »
I've found a work-around for this problem.
Install Free Mouse Auto Clicker http://www.advanced-mouse-auto-clicker. ... otial.html
Set Xnview so that Transition = "Use Timer" is on and "Use keyboard press or mouse" is off.
This should give "MouseNav = 0" near the top of the SLD file - edit it with Notepad if necessary.
Set the click interval in Mouse Clicker just less than the kick-in time for the screen saver.
If you set "Use keyboard press or mouse" to "on" and "Use Timer" to "off" the slideshow will advance when auto clicker activates.
Peter2
Post by Peter2 »
rtbcomp wrote:I've found a work-around for this problem..
I didn't test it in combination with the Slideshow, but Caffeine is a fine tool ...
rtbcomp
Post by rtbcomp »
Thanks for that Peter.
I've just run a slideshow for 30 mins with my screen blanker set to 10 mins and it worked fine.
I didn't bother setting any parameters.
Cheers,
Roger
