Open advanced search
Click Seach
New search box opens and it shows 2 cancel buttons.
0.72 Cancel button 2x
Re: 0.72 Cancel button 2x
could you post a screenshot?
jadO
Seems to happen with large folders when seach takes quite a while. And you should check to search in subfolders too.
Then it might look like this:
http://www.datafilehost.com/d/8f4d2caa
on small folder you don't have 2 buttons?
jadO
I could not see. However search might be quicker than my eye so I cannot tell for sure.xnview wrote:on small folder you don't have 2 buttons?
ok, it seems that Cancel and Abort are translated with same german wordjadO wrote:I could not see. However search might be quicker than my eye so I cannot tell for sure.xnview wrote:on small folder you don't have 2 buttons?
Right, looks like a bug in the German translation. I'll check and correct this.xnview wrote:ok, it seems that Cancel and Abort are translated with same german word
Please note that German translation of XnView MP is discussed in topic XnView MP - Translation - ** Deutsch - German
jadO
What is the difference between Cancel and Abort?xnview wrote:ok, it seems that Cancel and Abort are translated with same german word
