0.72 x64 Mac OS X Yosemite 10.10.3
I cannot restore the Info Pane. When XnViewMP first started, it was there at the bottom of the screen. I dismissed it by clicking the X and now cannot make it reappear. All of the items are checked under View/Info Pane and I have tried all of the Layouts. The current layout is Free. Please advise how I can restore the Info Pane for showing EXIF, GPS, ExifTool, etc. Thanks!
Info Pane missing
Re: Info Pane missing
right click on title of pane, you have a menu to activate it
taijitu
Thank you, Pierre, I see that now. I right clicked on "Folders" at the top of the pane, selected "Info" and the Info pane reappeared as a tab with Folders. This happens with or without "Use Tabs" selected. Now, how can I make the Info pane with its own tabs appear separately from Folders? I had it that way a one point, but I can't make it reappear like that. Thanks in advance.
Drag the info pane to another locationtaijitu wrote:Thank you, Pierre, I see that now. I right clicked on "Folders" at the top of the pane, selected "Info" and the Info pane reappeared as a tab with Folders. This happens with or without "Use Tabs" selected. Now, how can I make the Info pane with its own tabs appear separately from Folders? I had it that way a one point, but I can't make it reappear like that. Thanks in advance.
