Add ability to open images from drive with no letter
Feature request.
It would be very handy to make it possible to open images from the drive with no letter assigned.
eg. potplayer can easily open video files from the same drive.
Re: Add ability to open images from drive with no letter
any thoughts? Is it possible to realize?
uRsti11anError
Post by uRsti11anError »
This can't be main way of opening files, only if additional. Because
Synetech wrote: it only works if you have NetBIOS and the RPC Locator running, so this won’t work if you have hardened Windows. In addition, you’ll probably need to keep several network-related services and drivers running to use it (Workstation, Computer Browser, Server, TCP/IP NetBIOS Helper, NetBT, DHCP, DNS, etc.)
Quote comes from this discussion:
http://superuser.com/questions/465730/access-to-a-disk-drive-using-volume-id-instead-of-a-drive-letter-in-windows
*wrapped link into code tags in case links to other sites are not welcome
