I often post pictures online, but need to blur out a serial number, phone number, or some other small piece of information, but I can't seem to figure out how to do that... Also, although it isn't really necessary, is it possible to insert text or a simple drawing (like a circle) with this applications?
Linux Mint 17.1
XnViewMP
Version 0.72 x64 (Dec 19 2014)
Blur a small section of image
Re: Blur a small section of image
A blur function is available in Image > Filter... > Blur but the available blur seems rather limited, perhaps you could report your experience on that...acejavelin wrote:I often post pictures online, but need to blur out a serial number, phone number, or some other small piece of information, but I can't seem to figure out how to do that...
Linux Mint 17.1
XnViewMP
Not implemented yet...Also, although it isn't really necessary, is it possible to insert text or a simple drawing (like a circle) with this applications?
acejavelin
OK, thank you
Drahken
You can apply blur to small areas by selecting trhem before starting the filter.
As far as the filters go, plain blur probably won't be effective. There are however other blurring filter; average, gaussian blur, soften, and while not technically blurs maximum and minimum. Soften is even less effective than plain blur. Average is the strongest standrard blurring filter. The maximum/minimum filters actually brighten/darken the image (respectively), as well as making it very blocky. With these filters which have a filter size option you make them blurrier by choosing a larger filter size (ie, 13x13 is the blurriest).
