0.75 playing video
B.Douille
0.75 playing video
Post by B.Douille »
Difference in the format of dates & times on many displays.
Version 0.75 only show Hours:Minutes :(
Version 0.72 always shows Hours:Minutes:seconds
I noticed Seconds are missed in labels under the Thumbnails, in file properties tab, EXIF tab and in the Change Timestamp dialog.
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
B.Douille
Re: No new bugs between 0.72 & 0.75??
Post by B.Douille »
With version 0.75 we can't play any video :(
The player buttons comes visible as well as the time bar, but the play button is inactive.
I tried in the browser / preview and in full screen as well. Same result.
We can even move the position on the time bar but no way to (dis)play any image from the video.
B.Douille wrote:Difference in the format of dates & times on many displays.
right
Strange, i have no problem. On Mov, avi? which windows?
B.Douille
Post by B.Douille »
2 machines, Win 7 32 & 64 bits. I checked AVI, WMV, MOV and MP4
Starting version 0.72 (same .ini file) the videos can be seen as usual.
m.Th.
Post by m.Th. »
B.Douille wrote:With version 0.75 we can't play any video :(
Same here. Checked with wmf, mp4 & Avi in Full Screen (F11)
m. Th.
in browser, you click on a video file, and play button is greyed?
fussfolk
Re: 0.75 playing video
Post by fussfolk »
I have searched the Forum for an issue on Video playback in XnViewMP, that I experience on a single machine from the first Installation throughout ALL Versions, currently 076.1 x64.
This happens to any Video and all kinds of Video files (avi, mts,...), in either preview or full-screen. In full-screen showing STILL Images is always fine, however, if VIDEO appears it's even infeasible to switch to the next slide (either STILL or VIDEO) - program has to be shut down and restarted.
The same Videos run fine in Windows Media Player, VLC or similar (e.g., if started from XnViewMP "Open (System)")
The machine with the issue explained above is:
Packard Bell ENBFXS, 6GB RAM, Win7 Home Premium SP1 64bit
K-lite installed.
(In parallel I have XnViewMP running on another machine yet WITHOUT that issue: Dell Latitude 3440, 4GB RAM, Win7 Professional SP1 64bit, currently XnViewMP 0.72 x64).
In XnView (Classic) that issue does NOT occur on the same machine (the Video playback implementation looks different there, but works well).
Any idea?
Beside that it's a great piece of software - appreciate it a lot!
Thanks and regards, fussfolk.
PS: See (my) example screen shot here (scroll down):
XnViewMP 0.75 use now WMF (Windows Media Foundation) codec no more DirectShow codecs
fussfolk
Post by fussfolk »
xnview wrote:XnViewMP 0.75 use now WMF (Windows Media Foundation) codec no more DirectShow codecs
Hi Pierre, thanks for fast feedback!
Maybe I do not get your point so far: Do I need to reconfigure something to assign WMF codec???
I think that Klite install WMF and DirectShow codec, but i'm not an expert of video codec :)
fussfolk
Post by fussfolk »
Well, in the meantime I have tried Klite as well as X Codec Pack, but same result: XnViewMP does not play Video via its built-in player at all, i.e., the player's control panel appears, but screen remains completely white (or grey), pressing start button (or any other button of Player Panel) does not yield any action. Even worse, I can not return from that empty player Screen to the General (thumbnail) Screen, just Close the Player Window, which Closes XnViewMP at all.
Any idea yet?
(As mentioned above, on a different Laptop I do not experience those issues (Win7 Professional there instead of Home Premium here).)
fussfolk
Post by fussfolk »
fussfolk wrote: (As mentioned above, on a different Laptop I do not experience those issues (Win7 Professional there instead of Home Premium here).)
Came back to this issue again yesterday and found out, that on the quoted Win7 Professional machine video playback does work on 0.72, but NOT on 0.76.1 anymore (no matter what video type).
So far I am still fine with 0.72, but any idea what has happened from 0.72 towards 0.76.1 regarding video playback?
fussfolk wrote: Came back to this issue again yesterday and found out, that on the quoted Win7 Professional machine video playback does work on 0.72, but NOT on 0.76.1 anymore (no matter what video type).
i've sent you a PM
