Multiple databases
elfroggio
Multiple databases
Post by elfroggio »
I'm new to xnVieewMP, on xUbuntu 14.04LTS. Looks very good but...
Can I have 2 databases? Even specifying them through some command line parameters
I have 2 main directories:
  • photos: all the photos that are straight from the camera, including the out of focus, the img_xxxx name...
  • library: all the photos that I keep with structured directories: people, places, events, animals...
Photos: is transient, that's where I check for focus, renames and delete the 'bad' photos... I basically want to use xnView as a browser. I do not need any database feature, no category, no ranking... Just delete and renames.
Library: That's where I keep my 'keepers'. There, I keyword, tag, rate....
Any suggestion on how to do it or what are other people doing?
Thanks
Syv
Re: Multiple databases
you can use 2 different xnview.ini with different location of database
elfroggio
Post by elfroggio »
xnview wrote:you can use 2 different xnview.ini with different location of database
xnviewmp -ini ~/xn01/xnview.ini
and
xnviewmp -ini ~/xn02/xnview.ini
Thank you very much
Syv
elfroggio
Post by elfroggio »
Tried it and it still points to the same XnView.db. I do not see where in xnview.ini, I can set the the path for the second XnView.db or give it a different name.
Thanks
Syv
Tried it and it still points to the same XnView.db. I do not see where in xnview.ini, I can set the the path for the second XnView.db...
Possibly here:
[DB]
basePath=/
...I can set the the path for the second XnView.db or give it a different name.
Presumably if the path for the database is a base path, the XnView.db files shouldn't be renamed or they won't be found?
[Edited.]
