I just purchased a copy of the Pro version of XnView and the problem I'm having is I wanting to do a batch Convert and Resize of some Pictures I took that were in RAW format and I did not change any setting's other then to Convert them to Jpeg and the size to 1600X1200,the problem was the pictures turn out much darker then the original pictures.
When using the same method with other program's I have never had this happen to me before,the Camera I used was a Nikon D5200 and the format was in RAW.
Problem with XnView.
Re: Problem with XnView.
you can try to use embedded jpeg, disable option>Read>Raw>High quality
wade7575
Ok thanks I will try that.
wade7575
I have tried to find the features on how to do this can you tell me what tab's I need to click on,also once this has been set will it remember my setting's.
xnview wrote:you can try to use embedded jpeg, disable option>Read>Raw>High quality
in option>Read-Write>Read>Raw, disable 'High quality'
