0.75 A black vertical line appears when viewing in...
senchiyo
Post by senchiyo »
A black vertical line appears when viewing original size and the original size is equal to or bigger than 3264×2448.
The black line always appears in the same position.
Basically I tested this bug for the pictures taken by iPhone, but I also found this bug in other bigger pictures taken by other cameras. So I am not sure the exact dimension for the bug occurrence.
This bug is only in 0.75. 0.72 is no problem.
Re: 0.75 A black vertical line appears when viewing in...
no problem in 0.72?? could you post a screenshot?
senchiyo
Post by senchiyo »
xnview wrote:no problem in 0.72?? could you post a screenshot?
0.72:
http://i.imgur.com/d6jLkGP.jpg
0.75:
http://i.imgur.com/Ac7YVmj.jpg
could you send me the file? Which display size do you use?
senchiyo
Post by senchiyo »
xnview wrote:could you send me the file? Which display size do you use?
File: http://i.imgur.com/9kvq195.jpg
My display size is 1024×600 or 1024×768 for different purposes.
senchiyo
Post by senchiyo »
This phenomenon disappeared in 0.76. :D
