Can't get XnView to open .KQP files
bkarlstrom
Post by bkarlstrom »
I downloaded XnView and anticipated I would be able to open some older Konica files (.KQP). But it does not work at all. I get a pop-up warning message (se attached) when attempting to open any files with the KQP extension.
Re: Can't get XnView to open .KQP files
bkarlstrom wrote:I downloaded XnView and anticipated I would be able to open some older Konica files (.KQP). But it does not work at all. I get a pop-up warning message (attached) when attempting to open any files with the KQP extension.
The setting you need is in the Tools menu so the full path is:
Tools > Options > General > Display all image file types
If the image still isn't displayed with that setting enabled could you upload an example file (2MiB max) or a link to a file?
Please refer to “KQP conversion to JPG”.
