[Duplicate] SHIFT+CRSR-LEFT stops at line-end while...
loth
Post by loth »
<Moderator's note: This topic is likely to be a duplicate, please add new posts in the similar topic.>
hi,
if you are in browsing mode, you can use the cursor to scroll through the thumbs.
if you try to select some files with the SHIFT-key you cannot scroll through the lines anymore. (means: you cannot move to the next row)
jsut try to select some pictures (must be more than 1 row of thumbnails in the browser window) with the SHIFT-key *and* CRSR-LEFT.
the focus will stop at the end of the line (window)
i would suggest two solutions:
0) the user can select,
if
1) s/he wants to scroll over the lines/rows (which should be the default behaviour)
or
2) s/he wants to scroll in "block-mode" (which is also very useful sometimes)
any suggestions?
loth
K.B.
:) Hi !
- It's a :bugconfirmed: known bug, recently Pierre told he'll fix this in a next version…
:mrgreen: KR
loth
Re: K.B.
Post by loth »
Clo wrote:- It's a :bugconfirmed: known bug, recently Pierre told he'll fix this in a next version…
ok, didnt find it while surfing the forum :-/
were the *two* suggestions part of the "fix" ? ;-)
loth
Both---
:) Hi !
were the *two* suggestions part of the "fix" ? ;)
• I guess both issues will be fixed together… (Hope feeds the life !)
:mrgreen: V G
Dreamer
Post by Dreamer »
Here, or do you mean something else?
loth
Post by loth »
Dreamer wrote:Here, or do you mean something else?
if you typed in my direction: yes. :-)
loth
Same
:arrow: Dreamer
:) Hi !
- I think they are the same issues…
:mrgreen: KR
Dreamer
Post by Dreamer »
OK, so continue there...
