IPTC/XMP caption encoding on Windows and Linux
rmtk
Post by rmtk »
I found that all IPTC/XMP captions in Chinese I wrote on Linux version of XnViewMP turn into unrecognizable characters on Windows version, while Chinese captions wrote on Windows version is not readable on Linux version either.
Seem to be an encoding issue.
Re: IPTC/XMP caption encoding on Windows and Linux
in XMP metadata too??
you can change iptc encoding to utf8
rmtk
Post by rmtk »
OK, now solved.
I think it's better to set "use utf-8 to write iptc fields" as default.
Taho
Post by Taho »
could you tell me please how I can set "use utf-8 to write iptc fields" for Windows? Where is this item in program settings?
Taho wrote:could you tell me please how I can set "use utf-8 to write iptc fields" for Windows?
Tools > Setting...
Taho
Post by Taho »
Cday, thanks for the answer!
But I can't find function of edit IPTC data. In XnView - Edit -> Metadata -> Edit IPTC data. And I can to do it in XnViewMP?
Taho wrote:... I can't find function of edit IPTC data. In XnView - Edit -> Metadata -> Edit IPTC data. And I can to do it in XnViewMP?
It's moved:
Tools > Metadata > Edit IPTC/XMP...
Note: I don't use the browser, I just like a challenge... :wink:
Taho
Post by Taho »
Thanks!!!
I found IPTC metadata edit. I can hotkey ctrl+I also. UTF8 - it's cool!
Kartoffelr
Post by Kartoffelr »
rmtk wrote:OK, now solved.
I was irritated when i saw that it is not!
In v0.84 (and probably earlier), "Use utf-8 to write iptc fields" is on by default.
:arrow: Closed
