Hi there
I notice that if I crop an image and navigate away, a dialog box appears saying "Do you want to save changes to 'XXXX.jpg'?" With a tickbox giving you an option to "Never ask again".
If the tickbox is ticked, indicating you DO NOT want to be prompted to confirm changes next time you edit a file, it doesn't quite work:
Next time a file is edited, when you navigate away from it, a dialog box appears - "The file XXX already exists! Do you want to overwrite it?" Yes, No, Options.
As far as I can tell there is no way to switch this dialog box off, rendering the previous option of "Never ask again" completely useless.
Many thanks
Simon
"Never ask again" save changed file
