XnView Window Size After Screen Capture
-sushi-
Post by -sushi- »
Thanks to the developers for a terrific program! :)
I am using the latest XnView - when I do a screen capture (for example my computer desktop), XnView reduces in size and I need to maximise the window. You can see what I mean here:
http://www.members.westnet.com.au/emmx/xnview.jpg
Any suggestion to make the XnView window stop going to this size and staying at the correct size would be appreciated.
Cheers
How I do---
:) Hello !
- You can get the Desktop image (for instance) with the 1/1 scale, simply press the PrintScreen key, then paste in XnView with Ctrl+Shift+V.
- Press NUM* to get the capture as the 1/1 scale.
- Save the pic as any name and format with Ctrl+Shift+S or the "Save as…" entry of the "File" menu…
:P Longer to explain than to do !
:mrgreen: Kind regards,
