XnView as limited user
molecule
Post by molecule »
How do I install for limited user in XPproSP3 ...
In setup, I created two accounts, User_1 and User_2. By default both were admin. On first logon, I create Docs & Settings for User 1, as admin, and install software. I then logon as User_2, and create Docs and Settings for User_2, and then move the XnView startup link from User_1 to User_2, but it has no icon and it is dead. I don't want to use as administrator rights. User_2 (actually me) can use XnView to view files owned by User_2 (I don't want to use admin level for general purpose any more.)
Should I reinstall XnView while logged on as limited User_2? Do Remove the 1st one? I don' t mind releasing admin rights to install, but I'd like to be limited user when surfing the internet, and have XnView avallable.
Thanks ...
Erixx haxx
Re: XnView as limited user
Post by Erixx haxx »
Go to the folder where xnview.exe is and create a shortcut and send it to user_2 desktop folder. You also need to use setings: store .ini as user
