The crop feature in the batch processing is needed with percent of width or height.
After scanning double sided document with variable width / height, the cropping must at 50% of any scan
Crop with percent
Re: Crop with percent
Have you looked at Canvas resize, I think it may be possible to configure it to provide the crop action that you require...PM_MainzX2 wrote:The crop feature in the batch processing is needed with percent of width or height.
PM_MainzX2
Hi cday,
that's great. To Edit the canvas size to Witdh: 50%, Height: 100%, Orientation Left-Middle was the reason.
Thank you
Thank you
