Hello, is there a way to navigate only within search results?
For example, I search for a name, and all the pictures within that name show up in the browser. I click on one of the pictures, and it opens up in a new tab. Right now, if I press right or left, the pictures include other pictures other than the search results. Is there a way to make it so that if I click on a searched picture and open in a tab, when I click right or left I only navigate within the searched pictures? Like in windows explorer? Thank you.
0.84: Navigate within quick search results?
tylenolthumb
Re: navigate within search results?
currently not possible...
tylenolthumb
no probs man, maybe in the future
tylenolthumb
Hello how are you? Is this feature in the works? Thanks.
From what I can see this works in 0.84. Try it out yourself and you'll see best.tylenolthumb wrote:Hello how are you? Is this feature in the works? Thanks.
tylenolthumb
How do I get it to work? In a new tab, the "next file" and "previous file" buttons still go through all pictures in the directory, rather than just cycling through the results found by quick search.helmut wrote:From what I can see this works in 0.84. Try it out yourself and you'll see best.tylenolthumb wrote:Hello how are you? Is this feature in the works? Thanks.
Thank you for checking and your reply, tylenolthumb. Search and quick search are two different animals. I've just tried with quick search and can confirm that this doesn't work. Though, I'm not 100% sure what the expected behaviour is. ATM, I'd say that the list used for the viewer should base on the list in the browser and I'd consider this a bug.tylenolthumb wrote:How do I get it to work? In a new tab, the "next file" and "previous file" buttons still go through all pictures in the directory, rather than just cycling through the results found by quick search.
As a workaround you could try this: (see screen recording topic_32021_tylenolthumb.wmv)
1. Do quick search
2. Press Ctrl+A to select all filtered files.
3. Right click with mouse to open the context menu and select "Open".
-> Tab with image will be opened and when navigating with "Previous file" and "Next file" the previously selected images are displayed, only.
tylenolthumb
Thank you for the workaround, and especially the video, very helpful!helmut wrote:Thank you for checking and your reply, tylenolthumb. Search and quick search are two different animals. I've just tried with quick search and can confirm that this doesn't work. Though, I'm not 100% sure what the expected behaviour is. ATM, I'd say that the list used for the viewer should base on the list in the browser and I'd consider this a bug.tylenolthumb wrote:How do I get it to work? In a new tab, the "next file" and "previous file" buttons still go through all pictures in the directory, rather than just cycling through the results found by quick search.![]()
1. Do quick search
I'm glad you can use the workaround.tylenolthumb wrote:.. Thank you for the workaround, and especially the video, very helpful!
I'd expect that whenever opening the Viewer (view mode) the files currently shown in the browser are the basis for the file list used by the viewer. In our case only the files filtered by the quick search should be displayed in the viewer when navigating.
Do other users agree?
m.Th.
Re: 0.84: Navigate within quick search results?
Yes.Do other users agree?
Especially when „Open” has such an undiscoverable behavior and does NOT work with all types of files. (Eg. Raw files - why?)
m. Th.
Thank you for your feedback, m.Th..
Reproduced
Note: This is a suggestion/new feature. Nevertheless it should be handled as a bug because this behaviour is expected by users.
I can't reproduce, in view mode i have only the files selected in browserhelmut wrote:Thank you for checking and your reply, tylenolthumb. Search and quick search are two different animals. I've just tried with quick search and can confirm that this doesn't work. Though, I'm not 100% sure what the expected behaviour is. ATM, I'd say that the list used for the viewer should base on the list in the browser and I'd consider this a bug.![]()
