When I start the program in Windows 10, I get large icons instead of thumbnails. If I refresh view or change folder thumbnails are back. It worked fine under Windows 7.
Pentium G3220
ASUS H81-M
Intel HD graphics
Windows 10 32bit
No thumbnails in Windows 10
Re: No thumbnails in Windows 10
always?
akramar
Lets say it happens in 90% of cases. Somethimes thumbnails on folders are shown but thumbnails on files are not.
I tried new drivers without effect.
I tried different thumbnail compression but no change.
Windows 10 are fresh install.
do you have same issue with 0.75beta?akramar wrote:Lets say it happens in 90% of cases. Somethimes thumbnails on folders are shown but thumbnails on files are not.
akramar
Just tried fresh install of Windows 10 and 0.75 beta. No change. The first time I start the program it is OK, but when I start changing options, thumbnails are gone.
Dont know which options, I did not try them one by one.
I wish there was a reset to default option.
Could you post a short sequence of actions that consistently produce the issue for Pierre to test?akramar wrote:Just tried fresh install of Windows 10 and 0.75 beta. No change. The first time I start the program it is OK, but when I start changing options, thumbnails are gone.
Presumably there isn't, but you could possibly post that as a suggestion...I wish there was a reset to default option.
akramar
I dont have the sequence, and I am really not in a mood for another reinstall. I give you screenshots of my settings and preffered program view. As soon as I refresh view (F5) or change folder, thumbnails are back and everything is fine.
Don't be confused by Croatian Windows. I currently use ACDSee as a replacement but would really like to go back to XnView.
http://www.mediafire.com/download/7eot2 ... XnView.rar
Global settings? or thumbnails options like sort, mode, ..?akramar wrote:when I start changing options
