XNviewMP: Files are deleted if using "Change timestamp" tool
dadde
Post by dadde »
Using the "Change timestamp" tool and changing the date of an open file (file already opened by another tool), there is no error but the file is removed from the folder without any notification. The trash is also empty and there is no way to recover the file.
As an example:
Change the "File Modified date" from "7/23/15 5:27 PM" to "7/22/15 4:17 AM"
This seems to be a bug and the inconvenience here is that it suppress the file!
If the file is only opened by xnviewmp this is working fine, otherwyse the bug appears.
Hope to see some fix for this.
Thanks and regards
David
XNView MPversion (latest from download): XnViewMP
Version 0.72 x64 (Dec 19 2014)
Libformat version 6.64
System env: Ubuntu 14.04 - 64 bits
Output of the tool:
ThumbLoaderThread :: stop()
### ThumbLoaderThread :: stop() ok
LOAD BITMAP </home/user1/Pictures/2015 - Star 2/IMG_1525.JPG>
GFF :: LoadThumbnail : 0
LOAD INFO </home/user1/Pictures/2015 - Star 2/IMG_1525.JPG>
### ThumbLoaderThread :: setFileList(330)
######ThumbLoaderThread :: forever 2 : 1544930
CHECK <1>
### START 330
######ThumbLoaderThread :: start : 1
LOADED & CREATED
ItemData :: update ==> IMG_1525.JPG
ItemData :: update ==> IMG_1525.JPG OK
######ThumbLoaderThread :: forever : 1544930
BrowserWindow :: updateMenu()
Create Tree : File
Create Tree : Image
Create Tree : Camera
CheckContent...
######### CategoryModel :: checkAndSave()
BitmapLoadThread :: stop()
### ThumbLoaderThread :: setFileList(329)
CHECK <0>
### ThumbLoaderThread :: updateFileList
### ThumbLoaderThread :: updateFileList ok
sizeHints : 298
### ThumbLoaderThread :: setFirstItemToLoad
### ThumbLoaderThread :: setFirstItemToLoad ok
CHECK <0>
Re: XNviewMP: Files are deleted if using "Change timestamp"
i can't reproduce. You open the picture file on which software?
