Hello!
Tnx for nice program, but I found strange in 0.72 version then convert from PNG (with transparent backgound) to JPG (right click to PNG image and "Convert into" JPG.
I mean strange artefacts instead transparent part of PNG.
PNG and result JPG attached
PNG to JPG convert problem
Pekkonen
- Forum Librarian
Re: PNG to JPG convert problem
Hello Pekkonen. Welcome to the forum.
A workaround is to convert the PNG from 32-bit (RGBA) to 24-bit (truecolor) first in order to “flatten” the alpha channel transparency: Image » Change color depth... » 24 bits
