Shortcuts for "Find similar files" feature
lccostajr
Post by lccostajr »
The "Find similar files..." feature is very useful and it has been working quite well. However, when you have to deal with lots of files it is very inefficient and time consuming to perform all actions via the mouse right-click.
Would it be possible to add shortcuts to the possible actions to be performed?
My typical workflow is to browse files and decide for each one if it must be deleted or not.
It would be great if I could only use the keyboard for this task.
