Batch Convert -> Add Text - Shadow - Transparency
dietmar
Post by dietmar »
Pierre,
during batch convert, the options for adding text allow you to select the text transparency. There should be another option to also select a transparency value for the text's drop shadow. Or at least the drop shadow should honor the text's transparency. As far as I see, the shadow is always 100% opaque where it's not washing out. Or do I miss something?
Regards
Dietmar
m.Th.
Re: Batch Convert -> Add Text - Shadow - Transparency
Post by m.Th. »
No (unfortunately).
m. Th.
