hi, first thanks for letting me join the forum.
I have problem with latest version (0.75)
When I install it, at the end of process, vcredist seems missing from installation progress.
Also, when I look at the shortcut and shell, they're still looking for xnview.exe, not xnviewmp.exe.
XnViewMP x64bit, Windows 8.1, first time install
hash SHA-1: E09FD50A43AA2A9E9005CD38574337AE9216DD8A
thanks..
installer & shortcut problem
Re: installer & shortcut problem
yes right, i've updated the package...
arch21
thanks for quick fix.
I'm sorry for posting on the wrong section
I wonder why I can find xnview.exe with zero bytes sizes.
anyway start menu entry still targeting xnview.exe, I changed manually to fix this.
