[Linux V0.75] missing librairie libQt5MultimediaWidgets.so.5
Roumano
Post by Roumano »
It's not directly a issue in XnViewMp but i can't lunch the new version of XnviewMP (0.75) :
error while loading shared libraries: libQt5MultimediaWidgets.so.5: cannot open shared object file: No such file or directory
Since i follow the MP version i was see this kind of issue :) (my 0.72 work as a charm)
I'm using a Gentoo & i have try to install the dev-qt/qtmultimedia but it's help
A quick search on google about libQt5MultimediaWidgets.so.5 say it's on the libQt5Multimedia but i don't have this kind of package
Do you known wich dependenci it's needed ?
Thanks in advance
Re: [Linux V0.75] missing librairie libQt5MultimediaWidgets.
do you have libQt5MultimediaWidgets in lib folder of XnView?
xzel
Post by xzel »
I am having the same issues on Fedora 22
02:51 xzel@zebx XnView $ ./XnView
./XnView: error while loading shared libraries: libQt5WebKitWidgets.so.5: cannot open shared object file: No such file or directory
02:59 xzel@zebx XnView $ ls lib | grep WebKit
libQt5WebKit.so.5
libQt5WebKit.so.5.4.2
libQt5WebKitWidgets.so.5.4
libQt5WebKitWidgets.so.5.4.2
