Many multimedia files won't in XNviewMP 0.75
TGB_72
Post by TGB_72 »
XnviewMP v0.75
mp3 with embedded cover art (id3 v2 tag) wont' play instead only the cover art is shown in the preview pane
flac files won't play in preview
rm asf vob wmv vfw flv mkv divx avi won't play in preview pane
Re: Many multimedia files won't in XNviewMP 0.75
TGB_72 wrote:XnviewMP v0.75
and play in 0.72?
TGB_72
Post by TGB_72 »
No, it has the same problems, so support for these formats were not implemented yet? I
In Xnview classic most of the files play fine (with exception of .flv)
TGB_72 wrote:No, it has the same problems, so support for these formats were not implemented yet? I
XnViewMP doesn't use the same functions, so you can have difference...
TGB_72
Post by TGB_72 »
So it never gonna work, it's not a bug? Do I need an additional codec pack in order to make it work?
TGB_72 wrote:So it never gonna work, it's not a bug? Do I need an additional codec pack in order to make it work?
it works for me for many formats with klite codec pack
TGB_72
Post by TGB_72 »
But don't XnviewMP comes with ffmpeg embedded? It supposed that ffmpeg can decode those format without the need of external packs.
TGB_72 wrote:But don't XnviewMP comes with ffmpeg embedded? It supposed that ffmpeg can decode those format without the need of external packs.
ffmpeg is only used to extract thumbnails
TGB_72
Post by TGB_72 »
Well, what a pity, ffmpeg could ensure support for tons of video and audio formats and correct decoding in most of the platforms.
TGB_72 wrote:Well, what a pity, ffmpeg could ensure support for tons of video and audio formats and correct decoding in most of the platforms.
With Klite codec pack, you'll have more formats supported
TGB_72
Post by TGB_72 »
xnview wrote:With Klite codec pack, you'll have more formats supported
Well, I installed k-lite and now most of the audio and video files plays perfect except for mp3 with embedded cover art, in that case the preview only shows the embedded cover art but it doesn't play the file, no problem with mp3 without embedded covers. Flac files play perfect even it it have embedded cover.
I'm using XNViewMP 0.81 and K-lite codec pack standard 12.2.2 on Windows 7 64 bits.
