Files in Taskbar - Extension missing
Peter2
Post by Peter2 »
Some files in the taskbar are missing the extension (e.g. JPG), and this is why it can't be found if it's clicked (although the files really exist). PNG and TIF seem to be OK.
Re: Files in Taskbar - Extension missing
where do you have that?
Peter2
Post by Peter2 »
It is the standard menu from the taskbar (Win 7 x64, XnView 2.34)
Peter2 wrote:It is the standard menu from the taskbar (Win 7 x64, XnView 2.34)
It is the menu displayed when right-clicking on the program icon on the taskbar, labelled 'Recent' in English...
Extensions displayed correctly for me with Folder Options > View tab -- 'Hide extensions for known file types' unchecked.
Peter2
Post by Peter2 »
cday wrote:Extensions displayed correctly for me with Folder Options > View tab -- 'Hide extensions for known file types' unchecked.
I display always all extensions and hidden files and system files and .... - but some extensions are missing.
