Version 0.75 crashes 2 days after upgrade
Moderator: Dreamer
Re: Version 0.75 crashes 2 days after upgrade
FloWil wrote: would you mind compiling xnviewmp for 32bit too?
http://www.xnview.com/beta/xnconvert.tgz
http://www.xnview.com/beta/xnview.tgz
Shnoober
Post by Shnoober »
I gave it a more thorough test and everything appears to be working. If you don't mind me asking, what was the problem?
Also, will it be a while before this patch is incorporated into an official release?
Shnoober wrote:I gave it a more thorough test and everything appears to be working. If you don't mind me asking, what was the problem?
I don't know, i've rebuild version on Archlinux, but this version doesn't works on ubuntu (glibc)... i must find a better solution...
Shnoober
Post by Shnoober »
I hope you figure it out and thank you for the work you've done so far.
FloWil
Post by FloWil »
Hi Pierre!
I'm sorry, haven't seen, that there's a "page 2" in the forum already where you've posted the 32bit version.
Happy news - it's working again. Thanks so much!!
Please keep on making xnview better!!! :-)
BTW: Do you mind, putting new versions to the AUR?
The status of xnviewmp is "orphaned"? right now in AUR
Agian, thanks for your effort
Flo
Shnoober wrote:I hope you figure it out and thank you for the work you've done so far.
could you try something with original XnConvert exe?
In a terminal, type
(replace .... by the path)
export LD_LIBRARY_PATH=/home/...../XnConvert/lib
export QT_PLUGIN_PATH=/home/...../XnConvert/lib
gdb ./XnConvert
run
where
and send me the stack trace?
