[Linux v.0.75]: library not found
m7876
Post by m7876 »
0.72 worked well (and still works) but 0.75 does not start and leaves the message:
./xnview.sh
... /XnView/XnView: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by ... /XnView/XnView)
... /XnView/XnView: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by ... /XnView/lib/libQt5WebKit.so.5)
What to do?
Re: [Linux v.0.75]: library not found
QT Librairies use glibc 3.4, are you able to install them?
m7876
Post by m7876 »
Likely not.
This is very unfortunate that you changed dependencies.
m7876 wrote:Likely not.
Not me but QT, which distribution do you have?
m7876
Post by m7876 »
I understand what you mean. Yes, I am in the dependency trap and do not like it. Distribution is old and highly modified, identical on several computers, and I want to keep it as long as possible.
Point is that (1) I use XnVew for all its 17 years on many systems (so thank you for XnView!!!!!!!!!) and (2) 0.72 works so I deeply regret the situation when software which worked yesterday stop to work today.
m7876 wrote:I understand what you mean. Yes, I am in the dependency trap and do not like it. Distribution is old and highly modified, identical on several computers, and I want to keep it as long as possible.
yes i understand but i'm dependent on QT API
m7876 wrote:... I deeply regret the situation when software which worked yesterday stop to work today.
You can still use 0.72...
If you need to reinstall it the installer is available from old versions
m7876
Post by m7876 »
cday wrote: You can still use 0.72...
Thank you Cap :)
m7876
Post by m7876 »
xnview wrote: yes i understand but i'm dependent on QT API
Then, why not
http://stackoverflow.com/questions/2474 ... ly-with-qt
or
http://stackoverflow.com/questions/3214 ... nd-libstdc
Problem with LGPL license
m7876
Post by m7876 »
OK, then solution (I found it minutes ago, everything works now):
1) Download gcc source (current is >= 5.2 but 4.6.2 is enough) from here https://gcc.gnu.org/mirrors.html
2) Compile it (follow instructions, install missing libs if needed) -- it takes looooooong time but files which you need are ready much sooner than compilation finishes
3) Find files "libstdc++.so.6" and "libstdc++.so.6.0.16" (if you compiled the newer version, last number might be different)
4) Copy them to XnView "lib" subdirectory
5) Run XnView, it should work now
Similar problem with the solution is explained here: https://forum.qt.io/topic/25032/solved- ... -install/3
Pierre, could you please mention in the announcement that older systems might have this GLIBCXX problem? It is possible that other people have the same problem.
