Regarding the undocumented "NoDelayedPreview" option
tannim
Yahoo Messenger: tannimdragons
Post by tannim »
7 years ago, the NoDelayedPreview feature was added to XnView classic after this post http://newsgroup.xnview.com/viewtopic.p ... 01&p=73123
By adding NoDelayedPreview=1 to the browser section of the INI file, there would be no delay scrolling up or down between pictures with the keyboard/mouse.
Is it possible to have this already existing feature added to the xnview options section where it can be easily enabled upon installation?
Re: Regarding the undocumented "NoDelayedPreview" option
yes it works in fullscreen mode from browser view (F11)
tannim
Post by tannim »
But can you add the option to the options menu? Right now the only way to turn this feature on is to manually edit the .ini file. It would be used more if people can turn it on or off from inside XnView.
