When you enter a folder and select to show all pictures recursively. And then when you select one picture and double click it.
After that you close the picture and you see the explorer again, but no more recursive anymore. You only see the current folder.
It would be much better if you close the picture and if you go back to explorer the view is still recursively.
Bug or Feature?
Re: Bug or Feature?
I was able to reproduce this error. Let me add more info:
THIS DOESN'T WORK:
1. Click settings > interface > switching mode
2. Set double click to "browser <> viewer"
3. Select a folder that has subfolders in it
4. On top click the button "show files in subfolder". On the screen it will show all pictures in all subfolders within this main folder that is selected.
5. Now double click on one of the pictures
6. The picture opens in a new tab. Close this tab.
7. Instead returning to the main folder, it incorrectly returns to the subfolder this picture is located.
Interestingly, if you change the setting in step 2, it works correctly
THIS WORKS:
2. Set double click to "Browser <> Fullscreen | Viewer <> Fullscreen "
6. It correctly returns to the main folder
This error is similar to video playback error. Double clicking on videos is broken if the double click is set to "browser <> viewer" but it works fine in "Browser <> Fullscreen | Viewer <> Fullscreen ".
Tested with xnviewmp 0.72, 32 bit on 32 bit win XP
THIS DOESN'T WORK:
THIS WORKS:
Re: Bug or Feature?
After applying this step and switching back to "browser <> viewer" it keeps working in 0.94b2.Teo wrote: Mon Oct 05, 2015 1:09 am Interestingly, if you change the setting in step 2, it works correctly
THIS WORKS:
So maybe it has been fixed.
