Set easily and print comment by picture
Benco
Post by Benco »
I have search the forum with keyword like "comment", "print", "embedded".
I'm looking for a way to quickly type for each picture some comments.
Then this comment to be printed above each picture.
I found the field "comment" CTRL+D, but then I was unable to print it.
I tried several field inside Print / Caption / Show information.
I tried several combination for the comment (stored in .io file or embedded) with my JPG file.
Finaly I found a round about using CTRL+I (caption for IPTC-IIM/XMP), and printing the field {IPTC:Caption}
is there a quickier way ?
Soft is great, congratulations.
Regards
Re: Set easily and print comment by picture
you can use Description and {Annotation} field
Benco
Post by Benco »
I put some word in the field "description (stored in descript.ion file)" that I got through CTRL+D "set comment".
in the layout with details my words are visible in column "Comment" (can't find a column "description")
I insert the field {Annotation} in the caption for print.
On the preview of printing nothing appear, neither on the real print (blank line).
it's a JPG file with XnVIEWMP 0.72 x32
Thanks for your help
right i've tried, it's a bug
