Mouse wheel for previous/next image
gost
Post by gost »
is there any possibility to setup XnView to work with mouse scroll. I want to setup mouse scroll for next and prev. image. Can I?
Thanks,
gost
ckv
Post by ckv »
Goto 'Options - View - Keyboard/Mouse' There set the 'Mouse wheel' option to 'Previous/Next image'. That should do the trick :D
Dreamer
Post by Dreamer »
Yes you can and you can still use zoom with a mouse wheel:
LMB + wheel = zoom + / -
LMB + MMB = lock zoom
LMB + RMB = reset zoom
You can use also RMB instead of LMB, but there is a little bug there (context menu).
LMB / MMB / RMB = left / middle / right mouse button
