0.75: Crash after installation over 0.72
UriF
Post by UriF »
I installed XNView MP 0.75 x64 over 0.72 and get error
Kolor crash reporter
XnView
An unexpected error has occured during software execution
debug information (Visual Studio 2013):
Unhandled exception 0x00007FFBE5AA1280 (ntdll.dll) in xnviewmp.exe:
0xC0000374: A heap has been corrupted (parameters : 0x00007FFBE5ADDD40)
ntdll.pdb not loaded
ntdll.pdb contains the debug information required to find the source for the module ntdll.dll
I tried your directory (downloaded zip versions)
http://download.xnview.com/old_versions/
I checked x86 version 0.75 - no problems
I checked x64 version 0.72 - no problems
I checked x86 version 0.72 - no problems
After this I tried a zip version 0.75 x64 and got the same error
Operation System - Win 8.1 x64
Re: 0.75: Crash after installation over 0.72
Do you have send the crash report? Please add your username in the report...
UriF
Post by UriF »
Thank you for reply.
How to prepare crash report and where it to be located?
UriF wrote:Thank you for reply.
I means send crash report via 'Kolor crash reporter'
UriF
Post by UriF »
I have a dump file. That's it
I could not upload dump file directly but I could create a zip file.
I also included a screen shot
I uploaded this dump file to Kolor (pressed button "upload")
i've sent ou a PM
UriF
Post by UriF »
I tried 0.76 x64. If in .75 application crashed in the moment when you double clicked at .exe but in 0.76 at first (for a approx 1-3 seconds) I see the XnView interface, and then I see a kolor dump screen.
I 0.75 portable version I was asked to debug immediately without the kolor dump screen. I could catch a color dump screen only if I would install application.
P.S. I repeat that x86 is OK
UriF wrote:I tried 0.76 x64. If in .75 application crashed in the moment when you double clicked at .exe but in 0.76 at first (for a approx 1-3 seconds) I see the XnView interface, and then I see a kolor dump screen.
0.76 x86 works, not 0.76 x64? could you send report?
UriF
Post by UriF »
XnViewMP
you are right. x86 - works, x64 - crash
UriF wrote:XnViewMP
could you download again the x64 package please, and send me the new dump file?
UriF
Post by UriF »
No problem
I got this file
XnViewMP-076-win-x64.zip 28-Oct-2015 07:30 45M
UriF wrote:No problem
I got this file
i've sent a PM
UriF
Post by UriF »
Thank you.
It would be easier to communicate
Sincerely,
Yuriy
do you have a dell?
UriF
Post by UriF »
yes, Dell XPS 8500 desktop
