Loading time
zafio
Loading time
Post by zafio »
I've noticed it takes XnViewMP to load way time than XnViewClassic, is there any way to speed it up to be closer to Classic?
Thanks.
zafio
Re: Loading time
Post by zafio »
Found out that executing it with admin rights speeds it up to 4 seconds, just slightly slower than classic, but acceptable.
Still, shouldn't it load at the same speed without admin rights? maybe it is a bug?
dh7
Re: Loading time
Post by dh7 »
Re: Loading time
Strange, do you have tried to rename the .db files?
zafio
Re: Loading time
Post by zafio »
Didn't help, but thanks anyway!
zafio
Re: Loading time
Post by zafio »
xnview wrote:Strange, do you have tried to rename the .db files?
No I haven't, should I? I mean, you ask because it could be what caused the slowdown, or because it could be the solution?
Re: Loading time
can be the problem
zafio
Re: Loading time
Post by zafio »
Well actually dh7's post helped. Moved the db to a flash drive and now it starts right away.
