Add field in the view with detail
fndun
Post by fndun »
Hi
Is it possible to add exif or itpc fields to the xnviewer overview with the details in the status line? In Order that you can use it like an explorer? for example, i like to add the exif usercomment an wouid like than to sort the picture in the view in alphabetically order following this exif usercomment.
Is there a list where I can see, wich field in the view with detais is corresponding to wich tag (exif, iptc, ...)
Thanks
fndun
Re: Add field in the view with detail
you can only use fields available
