I came across a "wmz" file today, it seems this is a zipped wmf.
XnView classic can read it and shows it like a regular wmf.
XnView MP 0.75 Win x64 crashes when it tries to generate the thumbnail (I sent a crash report)
0.75 crash with "wmz"
Re: 0.75 crash with "wmz"
please check the 0.76
Garamont
Merci, Pierre, for the quick response.
I installed the new version but at first it crashed again (I sent the report)
At the next start however, it did not crash, it just showed the Windows Mediaplayer icon for the wmz file and no Preview.
I thought there might be a difference in how I started XnView: when clicking the exe directly, it worked, and when using a link from Total Commander, it did not work.
But now I may have broken something else... it's crashing also when switching to some other directories, which worked before.
Sorry, I haven't got the time atm to try and isolate the problem more.
yes please check, and send the crash report if possible...Garamont wrote:But now I may have broken something else... it's crashing also when switching to some other directories, which worked before.
